fs-3140 c100 error
  • c.can
    • Aug 2025
    [Error Code] fs-3140 c100 error
    How do I use the Kyocera full simulation in turkey for this machine error?
    • 23010
    Re: fs-3140 c100 error
    WHAT MANUFACTURER? WHAT MODEL NUMBER?
    <add details here>
    MACHINE MESSAGE/FAULT/ERROR:
    <add details: error code, jam code, meter reading>
    STEPS TO RESOLVE ISSUE :
    <what have you done so far?>
    <what do you think is happening?>
    <what are you going to try next?>
    CURRENT CONDITION/STATE :
    <add details>
    ADVANCE SEARCH:
    <what have you read in the manual?>
    <what have you found in a forum search?>
    <results of Google?>
    If you'd like an answer this information is necessary.
    • c.can
      Kyocera fs-3140
      Error code C100
      İ can't find U021 in maintenance mode
        • 23010
        • AlbertK
          • Jul 2014
          • 90
          The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
          • AlbertK
            • Jul 2014
            • 90
            ...OH, and dont forget: 1. Remove the SKIP file in the firmware list
            2. Use KM_EMRG instead of the normal DL_CTRL
            3. Load DL_CTRL. directly after KM_EMRG.
            Good Luck
