FS 9530 F-000
  • Jude
    • Oct 2009
    • 256
    FS 9530 F-000
    Anyone ever seen this before on this box? The printer will reset after on/off but error returns. Pages will print but last page will stutter print as if formatting is off. then gives error. Please respond. I have the manual and have tried a flash using USB successfully. CF flash does not work gives an 01 error during CF format. MK needs replace is on and has been on for awhile. Any help is appreciated.
  • laitang
    • Nov 2012
    • 627
    Re: FS 9530 F-000
    From SM:
    F100: Operation panel PWB communication error
    Defective main PWB.
    Defective operation panel PWB.
    Replace the operation panel PWB or main PWB
    • AlbertK
      • Jul 2014
      • 90
      Re: FS 9530 F-000
      CF000 appears in 3minutes
      30 seconds after the
      Welcome display continues
      Panel-Main board
      communication error
      1) Check connection of the harness (Panel to Main board), (Main board to HDD)
      and connectors and check function.
      2) Check contact of the DDR memory by detaching and reattaching. and check
      function. replace it if available and check function.
      3) Format the HDD and check function. (U024 FULL formatting)
      4) Execute the U021 Memory initializing to initialize the controller backup memory
      and check function.
      5) Replace the main board and check function.
      6) Replace the Panel board and check function.
      7) Retrieve the USBLOG and contact the Service Administrative Division.
      The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
        • 23008
        Re: FS 9530 F-000
        Thanks Albert. Do you know where that spreadsheet came from?
        Two points:
        #1) Are you sure the CF card is properly formatted before copying the firmware to it? Is the firmware unpacked, and on the root of the card? And it's the correct firmware? If all those things are correct I'd start with the CODE DIMM with firmware.
        #2) Most likely you've got a corrupt print job repeatedly hitting the printer, that is not clearing from the print queue. I would take the printer off the network, connect it via crossover to my laptop, and print that way. I think you'll find that it works fine until you put it back onto the customers network. The next thing to do if find the PC that's sending the print job and delete the print job, or stop the spooler and purge it.
        • Jude
          • Oct 2009
          • 256
          Re: FS 9530 F-000
          BC: Thank and others that responded. Guys: I have the manual and considered everything it says. I did reseat connectors on the main boards and others. I could not format the card on the machine because I was getting an error. It gets an 01 error during format. Maybe I'll try another CF card. I tried to format using USB. The machine goes through format but when I print status page it looks like the same firmware is installed. Thanks for the help. Any other suggestions are appreciated.
            • 23008
            Re: FS 9530 F-000
            Do you have access to another Falcon III? The formatting is the same.
            Or you can do this:
            1) Clear contents of the CF card
            2) Install the folder structure that I provide to you.
            3) Copy extracted firmware to the root of the card.
            • Jude
              • Oct 2009
              • 256
              Re: FS 9530 F-000
              Thanks Cat. I will try on monday. Is this what the folder file structure should look like? edriveshotgif.jpg
                • 23008
                Re: FS 9530 F-000
                Yes. Don't forget to extract the firmware. It won't load in compressed form. I can tell it's compressed because of the "K" icon in front of the firmware.
                Three of those lines should not appear on the card:
                The compressed firmware
                The folder with the uncompressed folder
                The zipped folder with the formatting
                You should only see the five folders I provided to you and the two firmware files. That's it. Nothing else. =^..^=
                • Jude
                  • Oct 2009
                  • 256
                  Re: FS 9530 F-000
                  Ok thanks Cat. Really appreciate it. I hope you enjoyed your thanksgiving with your family.
                    • 23008
                    Re: FS 9530 F-000
                    Thank you, Jude. We celebrated early, about two weeks ago, while Mrs. blackcat could still supervise my preparation of the turkey and fixin's. She had her 2nd knee replacement 11 days ago Monday, and is cruizin' around with her walker.
                    Happy Thanksgiving to you and your family. =^..^=
                    • Jude
                      • Oct 2009
                      • 256
                      Re: FS 9530 F-000
                      Thanks to all that contributed to help me with this. Thank you BC. Your suggestion worked and so far so good with the FW flash.
                        • 23008
                        Re: FS 9530 F-000
                        Congratulations Jude. =^..^=
                        • Jude
                          • Oct 2009
                          • 256
                          Re: FS 9530 F-000
                          The problem just came back. Any other ideas?
                            • 23008
                            Re: FS 9530 F-000
                            Operation Panel
                            HDD
                            Main PWB
                            You can choose the order. I think I'd start with the op panel, then firmware.
                            On Kyocera you must reload firmware whenever you change a board. Disparate levels of firmware will error out the machine. =^..^=
