Kyocera 180
  • nokia88
    • Aug 2009
    • 72
    Kyocera 180
    Dear all,
    I have copier Kyocera 180; printing OK, print page (STATUS REPORT MAINTENANCE) very good , but copy function not OK (copy is faded)
    Action: cleaned scanner: mirror, lens
    The same result..
    Can you help me ?
  • blsquires
    • Nov 2008
    • 342
    Re: Kyocera 180
    clean mirrors again just with a damp clean cloth .you get a blue film on the mirrors which can give bad copy quality.
      • 23010
      Re: Kyocera 180
      I entirely agree. The gasses from the fuser filter up through the holes in the frames, scanner, covers, vents, and obscure mirrors #1, #2, and #3. Use 99.9% alcohol.
      I've had some success preventatively by using self adhesive mylar to seal up the various unsealed holes in the frames above the fuser. =^..^=
      • Corder
        • Nov 2014
        • 105
        Re: Kyocera 180
        Originally posted by nokia88
        Dear all,
        The same result..
        Can you help me ?
        If you have good prints and bad copies there's not very much issues can exist. Mirrors, scanning lamp or user-defined settings for copying (toner saving or reduced contrast).
        • Josh93
          • Jul 2014
          • 47
          Re: Kyocera 180
          Make sure you rub em nice and good after your clean to remove any film from cleaner, and use a small LED torch or the such to check for a film ^as cat said with 99.9% there shouldn't be much film, if any.
          • nokia88
            • Aug 2009
            • 72
            Re: Kyocera 180
            Thanks all for your support, I'll check & clean scanner again
            • laitang
              • Nov 2012
              • 627
              Re: Kyocera 180
              If your optical unit is OK, perform maintenance mode U060:
              U060 Description:
              Adjusts the image scanning density.
              Purpose:
              Used when the entire image appears too dark or light.
              Method:
              Press the start key.
              Setting:
              1. Press the start key.
              2. Change the setting using the zoom +/- keys.
              Image scanning density Setting range: from 0 to 23, Initial setting:12
              Increasing the setting makes the density lower, and decreasing it makes the density higher.
              3. Press the start key. The value is set.
              Supplement:
              While this maintenance item is being executed, copying from an original is available in interrupt copying mode (which is activated by pressing the interrupt key).
              Completion:
              Press the stop/clear key. The screen for selecting a maintenance item No. is displayed.
