Reset message
  • raztech
    • Dec 2008
    • 88
    Reset message
    Good dayfor you
    have a message -the cartridge suply- is not original...want to reset this message to accept any kind of toner quality..
    may some one have a good idea about..
    thanks for you in advance
  • HenryT2
    • 962
    Re: Reset message
    Originally posted by raztech
    Good dayfor you
    You did not mention a brand or model .
    If you are asking about a Kyocera , I do not know of a reset for that message .......
    However ; with most manufacturers , if you use OEM toner ... you will not see that message.
    If you have seen this message , then it was probably recorded in the Event log ; thus voiding your warranty .
    Just use the recommended OEM toner .
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
      • 23009
      Re: Reset message
      If you have aftermarket toner installed, yes, it's going to say that. The reset? Install OEM toner. =^..^=
      • bob marley
        • Jan 2012
        • 1339
        Re: Reset message
        It is better to use only OEM toner to avoid many bad effects of non-original one
        Live for yourself and you will live in vain. Live for others, and you will live again
        • dbrownlee
          • Sep 2005
          • 197
          Re: Reset message
          I don't think that the warranty is voided unless the non-oem toner actually causes a problem. That's my understanding, anyway. But I've been wrong before.
          GO TIGERS!!
            • 23009
            Re: Reset message
            Unknown Toner will appear on the maintenance report, and yes, it will void the machine warranty. =^..^=
