TaskAlfa 8000i Tearing Fuser Unit
  • chris@kokstadcopiers
    • Jul 2014
    • 14
    [Jamming] TaskAlfa 8000i Tearing Fuser Unit
    We have a TaskAlfa 8000i in a copy centre and it keeps on tearing the fuser unit after about 80 000 - 100 000 copies. I have monitored it and there is nothing going through the machine that is damaging it. Could it be a paper jam that is removed incorrectly? Anyone with advice?
  • Max
    • Oct 2011
    • 554
    Re: TaskAlfa 8000i Tearing Fuser Unit
    There is a mod to fix this issue. I believe there is a jig to straighten the copier out where the fuser sits. Log on to kyocera tech support for details.
    • monstott2010
      This series had serious issues with fuser damaging itself when they were first released a couple years ago, but have been better since... there was a tech bulletin about it (search on www.kdaconnect.com for the bulletin "CORRECTIVE MEASURE FOR FIXING BELT DAMAGE" and even a jig to reposition the fuser frame to help resolve the problem.
        • 22999
        Occasionally, I still see a fuser that completely shreds itself, even when the previous one almost made yield. It's almost like the heat belt went through a shredder. =^..^=
          • Jul 2014
          • 14
          Thank you very much guys. Will look at servic bulletin again.
          • monstott2010
            I would agree.. we still see some issues, but not as bad as they were in the beginning... I had one fuser belt tear less than 24 hrs after installation.... that was the worst one I think I had to deal with
            • Tonerkiller
              • Oct 2012
              • 668
              We do not have any belts shredding anymore, but we still have the bearing failing. The fuser noise gets worse until it stops turning. The silent mode is on.
              • habik
                • 2013
                Our first fuser in the very first machines lasted 800k, the 2nd,3rd,4th,5th about 50-100k. The machine was returned on 6th change.
                Sent from my iDon't believe in marketing device using Tapatalk
                Firmwares HERE
                  • Jul 2014
                  • 14
                  According to some sources is the speed of the machine is causing the fuser to fail......
                  • Tulsa
                    • May 2014
                    • 20
                    After going through the nine different versions of fusers and the adjustment of 1 sheet can go thru but 2 cant horse****, they finally determined a defective belt plate in manufacturing. Once we received new fusers, it seems probably, though not completely solved, as significantly reduced.
                    Good luck.
                    • eddie110171
                      • May 2012
                      • 133
                      We had problems with a few of these even after using the jig, seems to be the lower to medium volume ones. We were advised by tech rep to turn on silent mode and reduce sleep to under 1 hour, preferably 30 minutes if you can get away with it. Even with sleep mode set at 60 minutes and silent mode it has helped a lot.
                      If you haven't used the jig to align the fuser start there 1st.
