deactivate card authentication kit (B)
  • copycoan
    • Sep 2012
    • 31
    Hello, i got a TASKalfa 3500i with the optional card authentication kit(B) installed and activated but with no card reader, i do not need this fuction at all, the machine works fine but there is a persistent message telling that there is not id card reader and i cant deactivate it. How can I unistall the authetication kit sofware in the machine?
    Thanks.
    (I tried sytem - optional function and shows that it is runnig but no button to stop or uninstall, and the sim for key counter/key card is off))
  • helms44
    • 3
    Re: deactivate card authentication kit (B)
    Thanks.
    I have the same problem on a machine and was wondering the same thing.
    • flimmer
      • Jun 2008
      • 30
      Use firmware ver. 04.00.0031 to reset
      • nickouk
        I have used used sim 221 usb host lock enabled to remove the message would need to sw off to upload firmware from usb flash
        • flimmer
          • Jun 2008
          • 30
          Only for 3050ci / 3550ci /4550ci /5550ci
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1901
            System Menu>system>optional function>disable card reader
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • copycoan
              • Sep 2012
              • 31
              ok thanks will try
              • tonerlung
                • May 2008
                • 27
                I have tried to remove the kit a few times but I think that once activated it is embedded on the main pcb and only replacement of this will sort the issue.
                • kkendric
                  • 301
                  I think it is in the Eeprom
