falah taan
  • falah taan
    • Feb 2013
    • 67
    falah taan
    helo every body please who can chenge speed kayocera 3050 to 50 ppm pleas if any one know help me please and thanks to all
  • habik
    • 2013
    Re: falah taan
    Put a sticker on front from KM5050
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • Zackuth
      • Aug 2009
      • 448
      Re: falah taan
      The only way is to pull all of the 3050 components out and replace with 5050 parts. It'll be cheaper to buy the KM5050 machine.
      If at first you don't succeed, redefine success
      • falah taan
        • Feb 2013
        • 67
        Re: falah taan
        Than a but want to use it or seal it I am you set to this photocopy
        • falah taan
          • Feb 2013
          • 67
          Re: falah taan
          Thanks but i want to use it not seal it I am used this photocopy
          • monstott2010
            Re: falah taan
            If you want to USE a 50ppm machine, you first have to BUY a 50ppm machine.
            • habik
              • 2013
              Re: falah taan
              If you know how the 5050 motherboard works and know how to re-program service ROMs and know how to change the latency and speed of motors you might have a chance. For sure you'll need to do some soldering. There was a hypothetical thread regarding this already, just no one is that brave and have that much time on their hands to do that. And in the unlikely event of someone that brave having success, I am 100% positive they would not share the secret of their know-how!
              Firmwares HERE
              • Tonerkiller
                • Oct 2012
                • 668
                Re: falah taan
                To make a 5530 out of a 4530 just cut the gray wire and reflash firmware
                  • 23009
                  Re: falah taan
                  All the gray wires ... yes? I've cut most of them ... =^..^=
                  • kkendric
                    • 301
                    Re: falah taan
                    The KM/CS 5030 uses a different main board than the KM/CS 5050 and the KM/CS 4050 and 5050 use the same board. It is not advisable to try to convert a 3050 into a 5050.
                    • habik
                      • 2013
                      Re: falah taan
                      Have you had any trials with converting?
                      Firmwares HERE
                      • kkendric
                        • 301
                        Re: falah taan
                        If you accidently put a 3050 Main board in a 5050 copier you will wind up with registration issues.
