250ci Poor copy
  • quitech
    • 82
    250ci Poor copy
    Dear friends,
    My customer return this taskalfa 250ci machine because of the copy quality, what must be the problem of this very machine. please view the attachment below and check if you have seen this problem, the production is checking, i swapped both LSU,drum unit and developer unit from working machine to this particular machine, no good result.
    • 22999
    Re: 250ci Poor copy
    Have you done any color calibrations? If not, get yourself a manual, and start reading. =^..^=
    • quitech
      • 82
      Re: 250ci Poor copy
      Dear B/cat thank for your contribution, i have done all the calibration several times both author gray adjustment, developer and drum refresh no good result. what am now asking is, can firmware correct this problem?
        • 22999
        Re: 250ci Poor copy
        How about AC calibration and half-tone adjustment? And they should be done in a specific order. One of these posts might be of assistance (this is found using a search engine):
        http://www.copytechnet.com/forums/ky...html#post77121
        http://www.copytechnet.com/forums/ky...-solution.html
        Still get the manual. It helps to know how the simulations are supposed to work. =^..^=
        • JBWiss
          • Dec 2014
          • 10
          Re: 250ci Poor copy
          Did you do the calibration cycle or the color registration (w/chart)? That looks like registration problem. I can't tell if you are getting a background, but if so, you may have to pull all the devs and drums and manually clean the lazer. The auto clean (I don't remember if it has one) doesn't always do the trick. All of this happens during a rough move. So if you move it back, do the registration again at end point.
          1
          Press the
          System Menu
          key.
          2
          Press [ ], [Adjustment/Maintenance], [ ] and
          then [Next] of
          Color Registration
          3
          Press [Print] of
          Chart
          . A chart is printed.
          On the chart, for each of
          M
          (magenta),
          C
          (cyan) and
          Y
          (yellow), 3 chart types are printed on one sheet:
          H-F
          (left),
          V
          (right),
          H-R
          (horizontal)
          • quitech
            • 82
            Re: 250ci Poor copy
            I thank you all my friends that show concern towards my problem especially my good blackcat and jbwiss for putting me through of what i will try tomorrow. The only problem i have now is the firmware, i which one of you can send it for me so that all my tools will be complete against tomorrow war. May God bless you all. You will hear from after the war.
            Thanks all,
            quitech.
            • kaborwen
              • Feb 2010
              • 146
              Re: 250ci Poor copy
              Hi,
              My think you have to replace the transfer belt for check. Thx.
