TA-5500i- F000
  • AlbertK
    • Jul 2014
    • 90
    TA-5500i- F000
    HI all
    I'm stuck with a machine (TA-5500i with no attachments) that gives me the famous F000 code after hanging on the "WELCOME" screen. Firmware update is not possible as the machine won't even read the USB. The Engine PWB turns all the motors ect.
    I think it's probably the Main PWB but here is my thought.... If I remove the DIMM memory or diconnect the HDD and the turn the machine on, should I get different code ? If the code stays at F000, then surely it has to be the Main PWB ?
    Any ideas....Please
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
  • laitang
    • Nov 2012
    • 627
    Re: TA-5500i- F000
    From SM:
    F000: Communication error between main PWB and operation PWB
    Posible cause:
    - Defective main PWB.
    - Defective operation PWB.
      • 23010
      Re: TA-5500i- F000
      It could be the op panel DIMM, or the op panel, or the CODE DIMM, or the main PWB, or firmware ... but that's about all the choices. Whatever you choose to do, remember to follow it with firmware. =^..^=
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1897
        Re: TA-5500i- F000
        F000.pdf
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Tonerkiller
          • Oct 2012
          • 668
          Re: TA-5500i- F000
          I just had one like this. Replace the hard drive
          • bronco31
            • Aug 2009
            • 174
            Re: TA-5500i- F000
            i just had one.. 3050ci.. stuck on Welcome/ F000...was the main board...411$ for a reurbed from Kyo... dont forget to swap out the little chip bottom right hand corner to the new main board..! then yes upgrade firmware... Thank You Lord, the address book and smtp stuff was still intact!
            • AlbertK
              • Jul 2014
              • 90
              Re: TA-5500i- F000
              Thank you all.
              I tested the HDD, it seems fine and even tried firmware from cf card. I ordered a Main PWB....will let you know the outcome.
              Regards
              • AlbertK
                • Jul 2014
                • 90
                Re: TA-5500i- F000
                Originally posted by AlbertK
                Thank you all.
                Regards
