FULL BLACK PAGE on kyocera FS-3140
  • LAURENT19
    • Mar 2011
    • 16
    [Electrical] FULL BLACK PAGE on kyocera FS-3140
    I've Suddently full Black Pages on FS-3140 .
    The printer indicate NOW
    " add toner please wait" but the cartridge TK350 is FULL and
    The WASTE TONER BOTTLE continues to fill.
    FOR TESTING
    I've change :
    - the development Unit
    - the Drum Unit
    - and a new Waste toner bottle
    After 10 min,
    The printer indicate always " add toner"
    And the waste toner is FULL AGAIN.
    I think a THT Problem OR Main Card.
    Thanks a lot for your ideas
  • Max
    • Oct 2011
    • 546
    Re: FULL BLACK PAGE on kyocera FS-3140
    Check the charge/grid bias connectors on the printer side. Possibly dirty or arcing.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1858
      It has to be high voltage arcing to cause it. make sure the drum is slid in & latched.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Tropico19
        Hey , Laurent19
        I have the same problem and no solution .I tried in addition to changing the main board and the THT board without any success .
        BiG problem !
        • copycoan
          • Sep 2012
          • 31
          same problem "adding toner" i tried drive unit, etc.. i changed a gear GEAR DLP Z31H (bulletin Measures against the Developer Drive Gear Shaft Twist), gears on dev unit dont rotate properly, check out with door open and with no toner, finally it loaded toner and start working.
          • ranachinna
            • Mar 2015
            • 11
            If you check toner inside one gear is there then you can swap that one
            All the best keep going on
