FS-4200 Take up / feed roller kit replacement procedure.
  • Hansoon
    • Sep 2007
    • 3391
    Have to replace the take up/feed rollers and separation roller of the FS-4200. My problem is that the customers creepy manager is always standing behind me and looking with eagle's eyes on what I am doing when I service his other machines.
    Have never seen a FS-4200 before and could use some info how to reach those rollers without looking too "Nooby".....
    Any hints please?
    Hans
    • 23010
    Re: FS-4200 Take up / feed roller kit replacement procedure.
    The most common thing I've seen is the enduser fiddling with with the retard roller and losing the separation spring. It would be a good idea to have one on-hand.
    For your convenience, remove the imaging components and tip the machine to the front. You can see everything just fine. Pictures? Here:
    • Hansoon
      • Sep 2007
      • 3391
      Thanks Cat, you're still on XP sometimes too?
      Hans
        • 23010
        I don't know how much longer that I can hold out. Both my laptop and home PC are on their last legs, and I still don't like Win7 or Win8. I'm hoping for a Win10 that I can use and understand. I've got 15 years worth of documents that won't take the application transition well. =^..^=
        • NeoMatrix
          Senior Tech.
          • 3513
          What documents do you need to move?
          I could probably knock out a small program to assit the transition.
          No guarantee.....
            • 23010
            Adobe and .txt documents seem to translate well. But Office 2000, not so well. Usually Excel and Word. If it matters, WinXP SP3 OS. I seem to lose the formulas from the Excel spreadsheets. And the formatting on Word docs goes to hell. =^..^=
            • NeoMatrix
              Senior Tech.
              • 3513
              Adobe and .txt documents seem to translate well. But Office 2000, not so well. Usually Excel and Word. If it matters, WinXP SP3 OS. I seem to lose the formulas from the Excel spreadsheets. =^..^=
              How about an app that converts all the Excel spreads directly into a searchable database? Full screen edit notate with images an notation pointers ?
              I thought about converting Ricoh Gooses Guide and Kyocera error codes to searchable database.
                • 23010
                Sounds useful. What application? =^..^=
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  The application I've had on the backburner for the last few years. I have to get enough mojo to finish and debug it into a stable platform. The PDF decoder has been a challege which has slowed the project down.
                  No excuse though, I should get the project going again...
                    • 23010
                    I can provide a couple of test documents when you get to that stage. =^..^=
                    • NeoMatrix
                      Senior Tech.
                      • 3513
                      Send a couple of smaller ones an I'll see if I can kickstart the mojo...
                      [Sorry Hansoon for hijacking the thread. I believe it's was solved by BC.....]
                      • Hansoon
                        • Sep 2007
                        • 3391
                        No problem pal. I'm interested in your project too. I'm using as much as possible W7 but for my accounting software still XP was needed until now. In the coming month I am forced to move to W7 too cause I am forced to upgrade that accounting software right now. Payed already much €€€€€ for the upgrade so no excuse not to start using it.
                        Hans
