500ci - colors "bleeding"
  • monstott2010
    • Jun 2025
    At least that's the best way to describe it... first noticed on full blue prints, but then can see with reds as well... have done all the normal clean/refresh/calibration cycles, u155 toner counts appear normal, sample sets attached... have replaced dev and drum with no change
    monbible.pdf
    • 22999
    Re: 500ci - colors "bleeding"
    It looks like cyan over-toning to me. You say that the developing unit is new? What U131 readings? OEM toner? Are you getting teardrop shaped toner spills on color images? =^..^=
    • monstott2010
      Replaced with developer from another machine (known good) to test and still have the same pattern, yes OEM toner, no tear drop toner spills... after more consideration, remember another tech replaced the transfer belt just before this started, going to check that out, maybe bad belt, or bad belt ground.... reaching a bit I think, but all things being equal, it kind of makes sense
        • 22999
        Make sure the primary transfer contact springs haven't been dislodged. It's easy to do, and 3 hours to fix. The good news is they can't go far, just on top of the HVT PWB. =^..^=
