Kyocera 4035 Scanning
  • midnite8
    • Aug 2025
    Hello,
    I am having trouble with my 4035. I have setup the scanner utility and address book, but the scanner only seems to be working for a couple days and stops until I restart the computer it is setup on. Right now I am only scanning to PC, a folder in my server.I am running scanner utility version 4.11.02. I have scanner utility and address always running and the computer never logs off or sleeps.
    • 23010
    Re: Kyocera 4035 Scanning
    On installation you need to select the checkbox for "Install As A Service". I've never installed it any other way. =^..^=
    • midnite8
      The installation has nothing that says install as service
      • Reed
        • Feb 2011
        • 258
        Try installing the earlier version 3.16.9 in desktop mode. I have trouble scanning to newer computers running windows 7 and 8 using the file utility 4.11. However the earlier version has seemed to work.
        • midnite8
          The previous version was 3.16.9 I believe, I have setup tasks scheduled to always start both address book and scanner utility when the computer boots up.
          • midnite8
            Is there any benefits of installation as a service vs desktop mode? Which one is recommended? I went ahead and re-installed scanner utility version 3.16.9 as a service and Address Book version 1.3.0 on my server. I do believe I previously installed it as a service and not desktop mode anyway. Does address book need to be running as well together with scanner utility in order for scanning to work? My server is 2K3
