3050ci Registration
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1859
    3050ci Registration
    doc10660820150406122907.pdf
    The 11" is the lead edge, so my colors (or black) are off front to rear frame. It's worse in the center & better towards the top and bottom. I tried turning off the registration in U467, cycling power & re-enabling it. Auto or manual registration doesn't seem to make any difference.
    The troubleshooting lists replacing a board (Bulletin C048), but it's for paper moving shift, not front to rear. Any input appreciated. I'll probably order a black laser unit first.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • 22942
    Re: 3050ci Registration
    If you're the tech I know you are, you've done the registration adjustment at least a dozen times, probably a lot more.
    I've had to do it 3 times consecutively to get within range on a few occasions, and it was a VoyagerE as you might have guessed.
    The laser is the best choice in my humble opinion, closely followed by the engine PWB. The LSU relay PWB by all appearances is just a connector board, grouping together the harnesses into a neat bundle with nothing of consequence on the board.
    The hotline probably told you firmware ... and I would do it just to rule it out. But it won't make any difference. =^..^=
    • tmaged
      • Oct 2008
      • 1859
      I went back today & tried a few other things. U410 (even though the squares are out of registration) succeeds. U412 however, fails. It scans the first page then says "set default". One of our other techs went & tried a primary belt and it did improve some. He said the hotline told him to do the activate/deactivate of U467 as many as 10-12 times. The customer was closing & he was only able to do it a few times. We're starting to lean toward the engine PWB first. Considering the fact that pulling the finisher & AK to replace LSU units, the engine board may be easier to rule out first.
      Hope that helps !
      -Tony
      www.dtios.com
        • 22942
        Is it safe to say that scans remain unaffected? =^..^=
        • tmaged
          • Oct 2008
          • 1859
          Yeah, and the registration on the three colors is perfect. That doesn't make sense to me, as I thought black was the reference point ?
          Hope that helps !
          -Tony
          www.dtios.com
          • Kyo fan
            • Dec 2013
            • 368
            In this case, before replacing the lasers, I would try with adjusting the deflection mirrors on each CMY laser unit. It's what they recommend in case of deviation in vertical registration, and nothing else helps. You are gonna need allen wrench tool (hex key) for it. Just remove the waste toner box to access it:
            • subaro
              • Oct 2010
              • 1274
              Re: FS-C5100DN magenta unaligned
              read the entire thread for the above and see the solution this guy posted. I know this is for a printer, but the symptoms are the same and if you are going to replace the engine pwb, it may worth trying this before. You will have to do setup and calibrations if you install a new engine pwb anyway. printout the U00 and choose all. just a thought here and for your model may not be the solution, but worth a try anyway.
              [SOLVED]
              Hy guys, I've solved the problem.
              Firmware wasn't the problem, was garbage in the eeprom data.
              I contact Kyocera, and they explain me the way to reset the internal eeprom.
              You have to install the printer and share it. Then from another PC map a virtual lpt1 on the shared printer:
              NET USE LPT1 \\ip_address\share_name
              At this point send on the virtual lpt1 this command from a dos prompt:
              echo !R! KCFG"SVEG",208,10;EXIT;>lpt1
              wait a couple of minutes, restart the printer and for security recalibrate the machine.
              at the end, remove the mapped lpt1:
              NET USE lpt1 /delete
              For me has worked perfectly!!
              • tmaged
                • Oct 2008
                • 1859
                [ATTACH=CONFIG]28746[/ATTACH]
                I assume that would be laser skew ? Generally I would think that would be front to rear skew, but mine is good that way. It's the center of the page that seems to be off.
                Hope that helps !
                -Tony
                www.dtios.com
                • tmaged
                  • Oct 2008
                  • 1859
                  Thanks to Justanotherhack on DNet for the fix for this one. He suggested printing 089 & looking for light colored stripes, then replacing the offending laser unit. I did that with the black, and then was able to complete 410, 412 & the registration adjustment. I did it manually three times to get it close, then did auto reg. adjustment to finish it. I then went in to double check the manual print & they were all solid.
                  On another note, we had a 5550ci with a registration problem that was really far out whack as well. After checking the 089 prints, the black was relatively light. We replaced the DV unit on this one and then was able to complete the registration.
                  Bottom line, if you're fighting registration issues, check all your images in 089 & fix the offending color(s) first. These not being in range can throw the registration out of adjustment where it can't be fixed until the other is resolved.
                  Hope that helps !
                  -Tony
                  www.dtios.com
