UTAX CD 1250 error 2203
  • ar6565
    • 94
    When I scan to a Computer folder I have error 2203?
    Also I can configure the machine at Internet Explorer, isn't that mean that the connection is established.
    OS: Windows 8.1
    By the way I had a successful scan attempts 2 or three times before but now I had this error 2203 ?
    I still configure the machine at the Internet Explorer but couldn't do scan.
    Pls help.
    • 23003
    Re: UTAX CD 1250 error 2203
    Sure you can print to it. So you assigned an IP or let DHCP do it for you. And you installed a driver. Did you enter the SMTP credentials? It's not at all related to the print setup.
    Essentially you need to tell the scanner exactly where you'd like the scans to go. I'm sure Kyocera (or Utax) writes a very nice email setup guide. It's the same machine as a KM-5050. Maybe this will help:
    Take a look at the Advanced tab > SMTP
    If none of this makes any sense to you, please contact a network person. They'll know what to do. =^..^=
    • ar6565
      • 94
      That is good but I only want to scan documents on the UTAX 1250 and send it to a file folder on my PC but I have this error 2203.
      I made it before but now I have this 2203 ??
      • Kyo fan
        • Dec 2013
        • 368
        The folder you are scanning to has to be shared and permissions given. Don't use simple file sharing, but go to advanced sharing -> share this folder -> permissions and check "full control". If it's a domain, pull that user and check "full control".
        Under the SMB tab of the machine's web config everything has to be entered correctly:
        Hostname: The hostname of the pc you are scanning to, or it's IP address if it has a static one assigned to it.
        Path: Just the name of the shared folder you are scanning to (no need to enter full path, folder can be anywhere on the local machine).
        Username: The username of the user that's gonna scan. Don't refer to the control panel's username cause those are often changed. If windows 7 or 8, go to the C: -> Users, and there find the correct name (check theirs desktops if you aren't sure). If there's a domain, than login would be domain\username
        Password: the one user types when logging in, and if there's none, create a simple one.
        If all the mentioned is entered and configured correctly, and still it doesn't work, check the antivirus suite they might have installed. Some of those have firewalls built in that blocks SMB traffic. I've seen it lately at few of my clients where they've put F-secure (awesome AV and more, btw) server edition which stops all the SMB traffic untill you create rules to allow it.
        • ar6565
          • 94
          I turned off Windows 8.1 Firewall for both its private & public network and I did scan to a File Folder and it work good. So it was Windows Firewall.
          Now this fire is On again.
          But now which firewall apps should be on to allow me scan to a File Folder. Windows 8.1.
          • ar6565
            • 94
            Did anyone know HOW to make this Wondows8.1 firewall let me scan form UTAX CD1250 to my PC (just a File Folder) without Turning firewall off for all the PC?
            Help Please.
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1875
              Create an exception in the firewall for the port to allow communications. Either Port 139 or 445, whichever one you are using.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • ar6565
                • 94
                I used a new tool/program called FREE PORT SCANNER and it tell that:
                Port No. 139 is closed and its name is: NetBIOS-ssn (NetBIOS session service)
                Port No. 445 is closed and its name is: microsoft-ds
                which one of them is to use here?
                • tmaged
                  • Oct 2008
                  • 1875
                  Use whichever one you had working. I think 139 is the default SMB port.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • ar6565
                    • 94
                    By the way Port 140 not 139 who was used and work when I turn off the windows firewall.
                    this 140 port only work when this firewall if off.
                    139 never work also the firewall turned off.
                    • ar6565
                      • 94
                      Did any heard about Kyocera Mita Scanner File Utility
                      Did that utility help to scan with Utax cd1250 machine?
                      I installed it but I don't know how to use it.
                      could anyone in the world help me to use that demine utax scanner
                      • tmaged
                        • Oct 2008
                        • 1875
                        Set it up scanning to email. Then there are no concerns of ports or software to install.
                        Hope that helps !
                        -Tony
                        www.dtios.com
