420i Printing slow
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1883
    420i Printing slow
    I know, we're all tired of seeing slow printing issues. I'm relatively network proficient, but am confused on this one. Customer has a 420i that prints PDF's slow. Sometimes like 30 minutes for 20 pages. They also have a 4501i that if they print the same document to, it prints fine. I assume it's a network issue, get their document on my laptop & print direct fine. Seems like case closed for me. Their IT tries different ports/cables/switch ports etc. hooks up direct & still doesn't work correctly. I go back to troubleshoot further. If I send the same job to both printers at the same time, the 4501i zips through the queue, while the 420i clunks through the queue one page at a time. For me, eliminating acrobat reader as a possible issue (they're using 11). I take a 1350DN, configure it with the IP address, using the cable from the 420i & it prints fine.
    Both NIC's are set to 100full on the 420i & 1000full on the 4501i.
    All workstations are printing direct to the IP address & are using 6.2.1113 version of the driver as am I.
    Pinging the machine seems to respond fine & nothing is on the same IP address.
    Some things seem to point to the machine & some to the network. I'm thinking of trying U021 ? Anything else I can use to narrow it down ?
    I may push the 420i to the location of the 4501i, but the 1350DN removed the doubt of the network connection.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • darry1322
    • Oct 2010
    • 817
    Re: 420i Printing slow
    I've resolved some slow printing by changing the driver and/or emulation.
    • subaro
      • Oct 2010
      • 1274
      • Kyo fan
        • Dec 2013
        • 368
        You pretty much covered everything. I would make sure it has the latest firmware, and maybe try with different ip address. Does it only happen with PDF's?
        • tmaged
          • Oct 2008
          • 1883
          Firmware is the latest & it's got 2gb RAM standard, along with a HDD. The emulation is set to KPDL(auto) on both machines.
          Hope that helps !
          -Tony
          www.dtios.com
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Can these machines print PostScript?
            If so, try LPRing directly to each: LPR -S <ip of printer> -P <LPR port of printer> c:\filename.pdf -o 1
            (Although it sounds like you may have already tried that.)
            This will eliminate both the application and the driver used.
            Acrobat and Adobe Reader can do some funky stuff. Sometimes a different app (like FoxIt Reader, for instance) may work better.
            Slow PDF printing is a REALLY old and common problem. It seems to effect all brands.
            • ss12
              • Jul 2008
              • 289
              2nd that on u21.had two fs3540,one would print at half speed of the other with the same file and configuration.U 21 sorted it for me
              • tmaged
                • Oct 2008
                • 1883
                What if anything do I risk losing by executing U021 ?
                Hope that helps !
                -Tony
                www.dtios.com
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  u21 is memory?
                  mostly network settings, and command center settings.
                  but problem like this i usually rule out network. Because sometimes even a simple improperly made pdf will expand to atleast 10 times its actual size(have seen 100x), that can slow everything down.
                  But since there's 4501 in the same office, i'd cross check driver and emulation as pointed out.
                  Idling colour developers are not healthy developers.
                  • Kyo fan
                    • Dec 2013
                    • 368
                    U021 can help in some cases, but i don't like it cause it wipes out event log, and i always like to see some of the machine's history.
                    • tmaged
                      • Oct 2008
                      • 1883
                      I backed everything up, executed U024 & U021, the reloaded everything. It seemed to work fine after that. Hopefully it's resolved & this helps someone else.
                      Thanks for everyone's input.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                        • 23007
                        Congratulations! Thanks for posting back. =^..^=
