KM3050 noisy panel fan in standby
  • Chillaholic
    • Oct 2010
    • 40
    [Misc] KM3050 noisy panel fan in standby
    Hey techs, I got a KM3050 which is making quite loud noises from the front panel. I changed the "FAN OPE 40-10" (302GR44010) but the noise didnt change a lot. Its still loud, tho the old fan was very dusty. Do you guys have any idea how to throttle the fan down in standby?
  • kjg
    • Mar 2009
    • 111
    Re: KM3050 noisy panel fan in standby
    Just replace the fan. They go bad. P/N 302GR44010 FAN OPE
    • Chillaholic
      • Oct 2010
      • 40
      Did you even read the text? I was even posting the same PN and name. I replaced it with a new one. But its still louder then it should be. Thats why I am asking if there is a way to throttle the fan down. The problem appears only in standby, because its the only fan running in standby.
      • kjg
        • Mar 2009
        • 111
        Oops. my mistake. I am guilty here of the one thing I dislike: Techs that post without reading whole text.
        I did read it but was distracted and posted quick reply.
        I sincerely apologize.
        In answer- I never had one that I replaced that was noisy after replacement. Perhaps try another fan? could be a bad one. I do remember some thin plastic film that the fan sat in perhaps to guide airflow. Could that be out of place and causing the noise?
        Just a thought.
        I hope it helps..
        If you are careful, you can keep the op panel up and turn it on to further isolate the cause.
          • 22999
          I've had a few of those fans that fit quite loosely in the plastic duct. When the fan spun up to high speed it would vibrate in a very annoying way. I used electrical tape, and wrapped 5 or 6 wraps around the outside edges of the fan, then used some additional force to snap-fit it into the duct. =^..^=
          • Chillaholic
            • Oct 2010
            • 40
            Hey guys thanks for your answers, I will open the panel again and see if it the fan is too loose. Electrical tape sounds like a good idea, I should try this and I will look for the plastic film to be in place.
            • copydocinc
              • Mar 2015
              • 263
              FYI the fan on the back of the machine, inside the print system back cover is the same fan, if you need another to try out.
