TA 400ci toner display
  • LNorris
    • Sep 2008
    • 645
    we have a 400ci that will not show toner level on screen or on the status page, says we have non-oem toner. it is oem. we have replaced the toner with new cartridge, same issue. we replaced the rfid board and it showed toner thru one copy (the status page) then went back to the non-oem thing.
    our next hunch per our tech rep is to replace both the rfid and engine board at same time. another tech is going thru this now to make sure no connector was left unplugged or not inserted correctly during another issue that he fought.
    any ideas or suggestions?
  • Tonerkiller
    • Oct 2012
    • 669
    Re: TA 400ci toner display
    I had the same issue a while back and replacing the board behind the toners fixed it.
    • LNorris
      • Sep 2008
      • 645
      yeah, the rfid board, did that and didn't fix anything....thanks for input tho...at least it makes me think we are on the right track
        • 23010
        Originally posted by LNorris
        .... another tech is going thru this now to make sure no connector was left unplugged or not inserted correctly during another issue that he fought.
        I did this to myself a while back. There is a union connector through the back frame, and while tugging on connectors to change the engine board, I unplugged the connector at the back of the rear frame:
        "Non-Kyocera Toner Installed", "Add Toner Black" or any other color, after changing the engine PWB. Connector at rear frame from the RFID PWB to YC26 on the engine PWB is only partially connected, due to difficulty in removing connectors from the engine PWB. Reseat the connector at the rear frame, from YC26 on the engine PWB to the RFID PWB.
        • monstott2010
          reload firmware then reset country code in maint mode
          • LNorris
            • Sep 2008
            • 645
            we think we have it, changed it from copystar to Kyocera back to copystar in mm. held up so far
              • 23010
              That's good to know. Thanks for sharing. =^..^=
              • Ctl-Alt-Del
                • Jul 2006
                • 430
                I wish I had tried that 4 years ago, we had one where the Cyan would always indicate non-oem, the end-user lived with it until they upgraded.
                • Kyo fan
                  • Dec 2013
                  • 368
                  Thanks for sharing. Got a 250ci with yellow status missing, gonna try this on Monday.
