TaskAlfa 3050ci - J4101 Z-folding jam
  • Dirk KM
    • Aug 2025
    [Jamming] TaskAlfa 3050ci - J4101 Z-folding jam
    Hi Guys I need some help here. I have a TaskAlfa 3050ci that is giving a J4101 jam code. The device is jamming with a Z-fold at the registration roller. If I try to make a print from the 2nd cassette or MP tray it will jam exactly the same way with jam codes J4102/4109 respectively.I have swapped the conveying unit and the registration section on the machine. I have checked the flat ribbon cables on the engine pwb and feed pwb as we had a previous case where the flat ribbon cables were at fault.
  • shanehunt2000
    • Oct 2011
    • 8
    Re: TaskAlfa 3050ci - J4101 Z-folding jam
    same problem here also 4001 jams
      • 23009
      Take a look at this thread. Maybe it will help:
      http://www.copytechnet.com/forums/ky...de-0000-a.html
      • Mike Watson
        • Oct 2012
        • 13
        Hi did you manage to resolve this issue as I have the same fault on a 2550ci.
        Many thanks
        Mike
        • Dirk KM
          Hey guys check your clutches, what I found was that the clutches corrode and then creates all kinds of chaos.On the 3050ci it ended up being the mid drive feed unit clutch that caused Z-folding.I have found that the clutches in the conveying units and feed drive units also corrode and causes duplex jamming/multiple feed jams/no paper feed jams respectively.
          • andyf424
            • Jun 2013
            • 126
            I'm helping a co-worker with a 2550ci that's doing this same thing. Going through the clutches next to see if that helps. Wish me luck......
            • Mike Watson
              • Oct 2012
              • 13
              Hi, it was one of the drive clutches that caused me this fault, I had to replace it in the end as cleaning did not work, I'm not sure which one it was as it was a little while ago, but I think it may have been either the main transfer belt drive clutch or the fuser drive.
              Hope this helps
              • andyf424
                • Jun 2013
                • 126
                This one turned out to be a one way in the fuser/transfer belt drive assembly. The one-way wore a groove in the shaft and was no longer biting. Ended up having to order a new drive assembly, customer is demanding a loaner.......
                  • 23009
                  Did you take a photo? How many clicks?
                  If the shaft isn't overly complex ... just a hole for a pin, or a slot for a clip, perhaps you can manufacture something? I've had some success with such things. =^..^=
                  • andyf424
                    • Jun 2013
                    • 126
                    No pics, clicks were about 200K. I was helping another tech out with this call, diagnosed the problem and had him order the parts. I hopefully will not be returning....
                    From memory, when I turned the transfer belt motor on the drive assembly the gear that drives the belt would turn but if I put any resistance on it with my finger, the gear would stop turning. I took the whole thing apart with the attitude of its already down, I can't make it any worse. I found a large white gear with a one way on it that had worn a groove in the shaft. Slide the gear to a fresh part of the shaft and it bit firmly. Had the tech order the whole drive assembly.
                    Thankfully I don't have many kyocera colors in my dirt so I won't be adding this to my car stock.
                    • tmaged
                      Owner/Service Manager
                      • Oct 2008
                      • 1888
                      Here's is the one from the 2550ci. This thread saved me some time. I thought it was a belt issue, as you can see the motor turning, but the belt didn't turn once installed. AndyF's description is what I experienced.
                      Thanks !
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                      • simonsays
                        • Aug 2013
                        • 95
                        Ive been told by tech support when the fuser is going bad and temp drops the machine jam at reg roller every time i didnt hear about the z fold though
                          • 23009
                          Originally posted by tmaged
                          [ATTACH=CONFIG]32861[/ATTACH]
                          Thanks !
                          Thanks Tony. I expect to see that one again.
                          • copier parts n.ireland
                            • Nov 2016
                            • 41
                            registration clutch ????????????
                            • copycoan
                              • Sep 2012
                              • 31
                              jam 4101, jam4111 ---> duplex clutches, there is two in the rear of the conveying unit, one at the top and one at the bottom each one gives one or the other jam code.
