Kyocera KM-5035 Finisher. Screen says: Attach finisher and close finisher door.
  • PCTECHMECHANIC
    • Jun 2015
    • 14
    [Error Code] Kyocera KM-5035 Finisher. Screen says: Attach finisher and close finisher door.
    The screen says to attach the finisher and to close finisher door however the finisher is attached and the door is closed.
  • Zackuth
    • Aug 2009
    • 448
    Re: Kyocera KM-5035 Finisher. Screen says: Attach finisher and close finisher door.
    The switches have a metal strip used to help push the switch down and the metal will bend over time. Just straighten the metal strip and it should work fine.
    If at first you don't succeed, redefine success
    • syrian technical
      i think this is the solution.
      • PCTECHMECHANIC
        • Jun 2015
        • 14
        Zackuth,
        Thank you very much for replying. Are you talking about the switches on the finisher door?
        • Zackuth
          • Aug 2009
          • 448
          Yes, the finisher door and the switch that lets the machine know that finisher is attached. I don't remember where it's at and don't have the style of finisher here. Once you see the switches you'll know what I'm talking about.
          • PCTECHMECHANIC
            • Jun 2015
            • 14
            Again, thank you very much for responding. I greatly appreciate it. I will try this first thing Monday morning and I'll let you know the results.
              • 22932
              I didn't record anything on it, but I've got a vague recollection of ordering a plastic bracket/microswitch holder. The enduser had gotten quite violent slamming the finisher. =^..^=
              • PCTECHMECHANIC
                • Jun 2015
                • 14
                Zackuth,
                You were spot on. Today I opened up took a look at the 2 strips and they were both bent so I straightened them out and when I reconnected the imager Voila, problem fixed. Thank you once again for you help, I greatly appreciate it.
                • Zackuth
                  • Aug 2009
                  • 448
                  You're welcome. Glad I could help.
