Kyocera FS-c2126mfp F000 (C)
  • ATSBMCO
    Technical
    • Oct 2007
    • 70
    Hello,
    We have two of the Kyocera FS-c2126+ here that have according to the manual faulty op panel or main PCB.
    Error F000(C)
    The first one works for a bit, about 5-mins, then eventually says F000 on the display. When we reboot the MFP it displays F000 straight away without any motor activation at all. You have to switch it off for 10-mins or so and reboot which then allows it to work for 5-mins again.
    We've re-installed fresh firmware and even tried older firmware too. Plus we've tried the back door firmware reboot system using a CF card too, but it still won't change the way it works. Even tried another op panel.
    The second one just goes straight into displaying F000(C), and won't do anything, and this includes no motor activation at all.
    Has anybody had any success with this fault?
    Help would be appreciated that's for sure.
    • 22599
    Re: Kyocera FS-c2126mfp F000 (C)
    You are correct. It's a communication error between op panel and main PWB. It could be either.
    Most likely the op panel is the less expensive guess. =^..^=
