Taskalfa 300ci
  • quitech
    • 82
    Taskalfa 300ci
    Dear friends,
    Good day to you all. pls friends i am facing serious challenge with one of my costumer's Taskalfa 300ci. The colour production is ok, while B/w production is faint, please check the attachment and tell me what to do.
    I swapped blk developer unith and blk drum unit from good working machine to this very machine, no good result.I swapped the LSU and charger board [HVT board] from good working machine to this very machine, still no good result.I have don both Ac calibration, drum refresh, developer refresh and Gray adjustment still the same. i initialize the memory with u21 no good result.
    pls any help will be highly appreciate.
    thanks all waiting for your help.
    Quitech
    • 23010
    Re: Taskalfa 300ci
    Is the black developer unit agitating? Possible bad developing motor. How about the primary transfer contacts, specifically black? Also, you may have a problem with the black primary transfer roller. Have you done an emergency stop to see how well the black image is developed on the primary transfer belt? =^..^=
    • Kyo fan
      • Dec 2013
      • 368
      Re: Taskalfa 300ci
      Replace developing and cleaning motor K.
