taskalfa 2551ci not printing with windows 10...anyone else having issues??
  • J_B
    • Mar 2011
    • 13
    I have a new 2551ci with job accounting enabled. All pc's work with the exception of 1 Windows 10 laptop.
    Issue: When printing from 10, the machine errors with improper code. But, if you go into the printer properties and select "test page" it WILL print that page fine.
    The code is good and works on all other pc's. All codes have no restrictions, solely being used for bill back.
    This machine is in a realtors office so I have the job accounting setup to "pop up" due to multiple users per workstation. I also tried to just embed one code to see if that helped. SAME ISSUE!??
    I installed the print driver manually as well as through the installer. I've also "shared" the driver on another pc (peer 2 peer) and then installed as a "network" driver on the 10 box. SAME ISSUE!?? Even if I have the "shared" pc due the page rendering....SAME ISSUE!??
    I've also reflashed the firmware to the newest 3.02 firmware.
    Anyone else seen this issue? Any help would be greatly appreciated!!
    JB
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: taskalfa 2551ci not printing with windows 10...anyone else having issues??
    Is the latested driver installed?
    The gene pool could use a little chlorine.
    • J_B
      • Mar 2011
      • 13
      Yes it is. If memory serves me correctly it is 6.2.11.13
      • JSC
        Gimp
        • Dec 2006
        • 618
        Yep, thats the latest. If its only the w10 machine (not done one of these yet) it must be to do with the driver not picking up the settings from the machine.
        • JDR
          • Jan 2015
          • 82
          Did you try win7 drivers ?
          • J_B
            • Mar 2011
            • 13
            That's the conclusion I was coming to. Everything I read says all win8 and 8.1 drivers are compatible. I know it must be true...it's on the Internet lol!
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1888
              Since Windows 10 isn't supported yet and is still technically a beta, doesn't seem to be your problem.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • J_B
                • Mar 2011
                • 13
                Doh! I thought ir released last month.. I see it's not until the 29th of this month.
                Guess I'll wait for kyocera to release their new driver.
                thanks
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  does windows 10 have "send directly to printer" option like previous versions?
                  Idling colour developers are not healthy developers.
                  • ThisPete
                    Too old to care
                    • Jun 2014
                    • 217
                    thanks
                    J_B, I've been printing to various Kyocera's and Minolta's with Windows 10 since early/mid March and had no problems at all (that have anything to do with the operating system).
                    To add to what jmaister said after you wrote that, for a long time there have been various problems using 32bit applications on a 64bit operating system.
                    From the driver notes of a 3050ci:
                    It may be too late to help you, but maybe it'll help someone else in the future.
                    Regards
                    • ThisPete
                      Too old to care
                      • Jun 2014
                      • 217
                      And again today, I had Adobe Reader(32bit) on 64bit Windows 10 that wouldn't send/print to a 'Custom Box' until I ticked "Print directly to the printer".
                      It just kept saying "Box not found" (or some such) !
                      Just glad I remembered what I'd written in this thread, it saved me a lot of time, it's not often I listen to myself!...
