Kyocera FS-C8020MFP Blank copies from Document feeder
  • xix76
    • Jul 2015
    • 7
    Hi All
    I have a machine that copies ok from the glass but blank copies using the document feeder. I have updated the FW and checked the home position of the scanner all looks ok. Has anyone seen this problem?
    XiX76
  • D_Ritter
    • May 2010
    • 16
    Re: Kyocera FS-C8020MFP Blank copies from Document feeder
    Hi XiX76,
    please ceck if the Scannerlock for Machinetransport is set to "Lock", so the Scanner can't move into the correct position for scanning from ADF.
    greetings and good luck
      • 23010
      Originally posted by D_Ritter
      Hi XiX76,
      I did this to myself too, LOL. Yes it's really easy to move the scanner lock on the left rear corner of the machine, so that the scanner cannot reach the home position under the slit glass. =^..^=
      • xix76
        • Jul 2015
        • 7
        Hi XiX76,
        Thanks Ritter this solved my issue..... It's not a normal machine I look at. If you need and Konica Minolta help let me know
