Scan via USB
  • Copystar Tech
    • Sep 2010
    • 59
    [Misc] Scan via USB
    I have a customer who has a FS-1135 in a very small machine shop connect by USB. He'd like to scan to e-mail or SMB, but I can't even figure out the TWAIN driver on the thing. Surprised I haven't run in to this issue by now. Any help would be appreciated.
  • darry1322
    • Oct 2010
    • 817
    Re: Scan via USB
    Load the twain driver on the PC.
    On the PC, go to Programs and set the TWAIN driver settings.
    Use TWAIN compatible software to scan.
    Looks to me like the TWAIN driver setting will use an IP address so TWAIN would need a network rather than a USB connection.
    • Copystar Tech
      • Sep 2010
      • 59
      Re: Scan via USB
      That's what I'm afraid of.
      • Kyo fan
        • Dec 2013
        • 368
        Re: Scan via USB
        FS-1135MFP doesn't have network twain, so it's usb only in that case which is tbh rather slow and inconvenient. Tell him not to be cheap and spend like 20$ on some cheap switch and one utp cable. Than he can do whatever he wants.
        • darry1322
          • Oct 2010
          • 817
          Re: Scan via USB
          I haven't personally tried TWAIN on an FS-1135. A kyocera doc I found online says it supports USB TWAIN, but the user manual instructions for setting the TWAIN driver includes entering the IP address of the device in the TWAIN driver. One of our techs was trying to get TWAIN to work and when I was walking him through the instructions on the phone, he said the TWAIN driver setup asks for the address of the copier.
          From all this I assume network TWAIN.
          Since the device doesn't have a HDD, I'm not sure exactly how it works but the 2550 used network TWAIN without a HDD.
          • nmfaxman
            • 1702
            Re: Scan via USB
            Almost all brands now require a network to scan.
            If they want a simple, use the software kind of machine, sell them a desktop model just for local printing and scanning.
            Most of these are designed for USB scanning. The bigger boxes require a network connection for scanning.
            Why waste money creating a scanning program when SMB and email are more stable and built into the machine that works with most platforms?
            • prskmr
              • Nov 2021
              • 1
              Re: Scan via USB
              it is possible to use twain driver using usb cable, there is option to select model with usb. no need to enter ip adress
              • Samanator
                • Sep 2017
                • 579
                Re: Scan via USB
                You might be able to make this work, but if you do, you (not some IT company or guy) will have to support it.
                .....just sayin'
                Good luck
                • copykat93
                  • Oct 2021
                  • 281
                  Re: Scan via USB
                  Why not just hand him a thumb drive and show him how to scan to USB memory.. easy peasy, & then he can pop it in his PC & do whatever he wants, email, edit, folder... the possibilities are endless
                  • CWP
                    • Jun 2013
                    • 168
                    Re: Scan via USB
                    I would hope this issue has either been resolved or machine upgraded - the original post is over six years old!
                    • PrintWhisperer
                      • Feb 2018
                      • 473
                      Re: Scan via USB
                      Right? I first saw the necro from the Bangalore guy and thought, ok he doesn't get it and probably still works with TWAIN.
                      After that....
                      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
