TA620 adding toner none stop.
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    The machine also says check toner cartridge. (not my actual call so i dont know the detail)
    We are thinking along the line of toner sensor, toner supply motor, or DV? KDA has a 6030 case where the toner supply drive was replaced.
    Has anyone else encountered one? what was the solution if you could kindly share?
    thx.
    Idling colour developers are not healthy developers.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: TA620 adding toner none stop.
    Set U152 to off.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23009
      I had a brand new CS-8030 that would not add toner right out of the box. There was a deformation of the "D" shaped bore in the toner cartridge drive coupler. With the right side cover off, I could easily observe what was happening. The coupler would not spring back because it was too tight on the "D" shaft. Ten minutes with my jewelers files fixed that. I opened up the bore just enough to let it slide on the shaft. =^..^=
      • Kyo fan
        • Dec 2013
        • 368
        I would try replacing developer unit 1st.
        • JUAN C DLS
          • Mar 2014
          • 14
          Check toner sensor with simulation.if sensor is reading ok, then
          Vacuum and clean the DV unit, then run DV set up again.
          • Copyguy71
            The toner drive gear on this model has a one way bearing that will strip, causing the machine to constantly run searching for toner. I've had to replace the toner drive pack many times
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              ding ding, turns out it was developer.
              thx gents for all the inputs!
