Kyocera FS-2100DN Fuser
  • hperkins
    • May 2015
    • 5
    [Misc] Kyocera FS-2100DN Fuser
    Is it possible to adjust the temperature on this model either on the machine its self or via driver?
    We have a client who is using a very old letter head, and when they print on it with a Ecosys P2135dn the letter head smears across the paper. So we are trying to figure out what model we can use that wont cause this problem. They have already told us that they have no plans of changing the paper or letter head they are using now.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1896
    Re: Kyocera FS-2100DN Fuser
    Have you tried running it as a heavier stock ?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • hperkins
      • May 2015
      • 5
      i have tried a few heavier paper settings but nothing seems to do anything. I was about to try maybe transparency paper settings. Maybe the fuser doesn't get as hot on that setting?
      • tmaged
        • Oct 2008
        • 1896
        If it's not fusing, you need it hotter more than likely. Unless there is some sort of odd finish to the paper. Changing the settings usually either
        changes the speed or temperature (or both) to be able to fuse the toner into heavier paper. This would be more desirable than changing the settings
        through simulations.
        Hope that helps !
        -Tony
        www.dtios.com
        • hperkins
          • May 2015
          • 5
          It's not the toner that's running. It's the pre-printed letter head graphics that once they hit the fuser they smear on the paper.
          • ntbann
            • Jan 2012
            • 631
            Rubber based pre-print. There is no way to stop it except to use the stock in a ink jet.
            • kjg
              • Mar 2009
              • 112
              You could try setting the envelope lever to the up position to relieve fuser pressure. That may limit the smearing.
              It sounds like a raised thermographic letterhead, almost like plastic.
              The lever is inside the rear door on the left side.
              I do agree that it will be difficult to get it to stop.
              The printer will run at a slower speed with the lever in the envelope position.
              Hope it helps.
              addendum:
              If this is a P2135 I am unsure if it has an envelope lever. the 2100 does.
                • 23010
                I had a customer that used to run all his own letterhead on a Sharp Bear, then run the black & white text on a Sharp Dragon. The Bear fuses at ~160C, and when it goes through the Dragon the toner would get stringy like taffy at the Dragons 180C fusing temperature.
                It a similar situation. There's nothing to be done. =^..^=
