KM-255c misfeeds J4211
    • 23009
    This Hanabi will feed fine for an hour, then when it's ready it will jam every page for a while. It's always J4211 which is ES (eject sensor).
    I changed the photointerrupter from scrap, which worked fine for about an hour. Then I though perhaps the two part flag linkage to the sensor was disengaging, because perhaps the gate was opening during feeding. So I used paper shims to shim that gate tightly closed. It worked nicely ... for about an hour. It did seem to primarily affect prints and internal reports, but that may be a coincidence. The main user had the wrong driver, and I thought I really had something ... for about an hour.
    Firmware is up to date. I haven't yet removed the bridge unit, and examined the bridge switches/sensors. There are always three pages remaining: one most of the way into the bridge, one page 25mm into the fuser, and one page at the lip of tray #1. I do not suspect the tray #1 feed unit, and the feed unit itself has been replaced prior to my visit. I do not suspect the fuser drive.
    Has anybody seen these J4211 jams? =^..^=
  • copymech
    • Sep 2011
    • 196
    Re: KM-255c misfeeds J4211
    Remove and reinstall your bridge unit. you may find a faulty connection
    • B0265
      • Jan 2007
      • 718
      You might find the solution in the attached file.
        • 23009
        Nice thought. That fuser is similar but does not have that spring/lever combination. =^..^=
          • 23009
          Does three times count? The bridge unit checks out visually. I'm leaning towards a heat issue affecting ES.
          The machine jams without the bridge. I quoted a fuser. =^..^=
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            theres a qa on this.
            the cause is due to the main spring in the fuser drive pack binding.
            the tip digs into the gear, and the other end catch on the metal plate so its tension kept building up to the point its strong enough to trip speed detection.(slowed)
            the fix is to have two shims on each side of the spring so that the spring spins with the gear and the tension never increases. as well, bend the tips inward, or order new stock.
            just lubing byitself is only good for 900 print... i tried that, but for permanent solution the shims are needed
            Idling colour developers are not healthy developers.
              • 23009
              Terrific! Thanks jmaister. Do you recall the shaft size, so that I can have the right shims/spacers on-hand?
              • jmaister
                certified scrub
                • Aug 2010
                • 755
                QA_E044_2NP_0005_SB_rev.1.pdf
                That's the QA.
                there are 2 polislider washer, and I think Kyocera went screwy on one of the part No.
                Washer A: diameter 20mm, thickness 0.5mm
                Washer B: diameter 18mm, thickness 0.25mm
                What's interesting about washer B is the actual part No. By this QA maybe they wanted to simplify it to be BC134840, but end up being 7BC06062J025C01<--- we ordered with this.
                KDA has 1 case also point to the fuser itself, to cover all basis.
                  • 23009
                  Perfect, thanks.
                  • tmaged
                    Owner/Service Manager
                    • 1890
                    I tried searching the wonderful database for the QA, but nothing. Do you have the number or can you post the QA ?
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • jmaister
                      certified scrub
                      • Aug 2010
                      • 755
                      yep, I've posted it.(its up there with previous msgs)
                      Getting the key word right searching the database IS A PAIN, tho this thing I just realized is only 2 months old.
                      • tmaged
                        • 1890
                        Not sure how I didn't see that ! I wish I drank, so I'd have an excuse.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        • Kyo fan
                          • Dec 2013
                          • 368
                          I missed this one too. Thanks for sharing jmaister.
                            • 23009
                            I'll confirm that this works like a charm. The only hazard I can see is snapping off the vulnerable plastic snaps attaching the two sides of the fuser drive pack, that by all appearances are entirely redundant, and unnecessary. After bending back both ends of the spring, I installed three shims: first between the metal frame and the spring, second between the spring and the inner gear, and third between the outer gear and the frame. And I slathered each of these spacer/shims with a little white lithium grease. 100% success. =^..^=
                            • jmaister
                              certified scrub
                              • Aug 2010
                              • 755
                              i saw the the actuall spring the other day, I think Kyocera has overdone it.
                              Make neccessary adjustment if you need to. Just remember that the purpose is not for spring ends to catch the surface its pressing against.
