MFX2010 how to reset fusing unit
  • rec6339
    • Aug 2012
    • 6
    Hello dear,
    I have MFX2010 for Muratec.The machine says "replace fusing unit".
    I'd like to know how to reset by pressing buttons.
    Could you help me ?
    Re: MFX2010 how to reset fusing unit
    Originally posted by rec6339
    Hello dear,
    Could you help me ?
    your new fuser should have come with instructions on " how to" ... you DID replace the fuser right?
    • scanmc
      • Mar 2015
      • 183
      Hello dear,
      Could you help me ?
      Not a US model
      • rec6339
        • Aug 2012
        • 6
        Thank you for advice.
        I have not the new fusing unit yet and I'm afraid it might not exist .I could reset drumunit .That has not a fuse,just press buttons.
        May be This model is used in Asia and Europe.
        I'd like to know if the fusing unit has a fuse to reset.
        Could you give me some advice!!
          mot sure about that model... most times it is just a flag reset in the NVR
          • rec6339
            • Aug 2012
            • 6
              a "flag reset" in NVR changes the fuser life setting in the software from a 1 to a 0 therefore resetting the life counter
              are you a tech?
              • rec6339
                • Aug 2012
                • 6
                are you a tech?
                I'm not a technician.but I have some kind of machines such as Konicaminolta,Sharp,Toshiba and etc.
                I wonder Flag reset means likely machine parameter,I ca see the parameter number ,8digit such as 10000101.
                Then changing the number,the fuser unit might be reset,right?
                Thanks and I try to find out the place to change.
                You are so helphull for me.
                Thanks again.
                  • 23010
                  If it were me, I would purchase a service manual, then read the appropriate section. Even an enduser can read a manual, yes? =^..^=
                    Thanks again.
                    if you just reset the counter and not the fuser you will be running into problems in the future .. they KNOW the approximate life of the fuser.. that's why that message comes up.
                    • rec6339
                      • Aug 2012
                      • 6
                      Thank you for advice.I'll try it.
                      • rec6339
                        • Aug 2012
                        • 6
                        Yes ,exactly you are right.I'll try to replace and reset using manual.
                        Thank you very very much again.
                        • faxgoddess
                          • Apr 2012
                          • 70
                          Since this machine is used in Asia and Europe, it will be different from the machines that are sold in the United States. Are you in the US or are you in Europe? You can always go to the Muratec website for Japan and request assistance. Here's the link: COMMUNICATION EQUIPMENT | MURATEC,MURATA MACHINERY, LTD.
                          "The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather in a lack of will."
                          --Vince Lombardi
