Kip 7000 "Roll Not Found" messages
    • 23009
    This is actually the second time I've addressed this. The first time I used the Restore Disk to resurrect it. Initially it was "Condition 52: Bad file name or number, Error checking D:\MONPATH1\LOGDIR\\StatInfo\KIPUnattend.Dat, Current Routine: tmrUnattendStatus, ErrorPlace 23". This screen gave me a good scare, but never re-occurred after a re-boot.
    Today I got a suggestion to change the C:\ drive. I was prepared to jump through the same hoops again, instead I got "Your BIOS is not compatible with this Product Recovery CD." Additionally I could see the blue light on the DVD player shutting off intermittently.
    I put the original drive back in, and attempted the Restore, same result. As a last ditch effort I got to the Diagnostics folder and ran Factory Default. It was looking good for a while there. It completed the ghosting of the drive, and the setup procedure, but would not hold the IP, subnet, gateway, and DNS, even after several attempts. The Key Codes did hold this time. Trays #1 and #2 are now recognizing paper, but #3 & #4 still do not. It will print reports and test pages, but will not copy, and since it won't hold an IP it won't print.
    Personally I think the IPS main board is toast. That might explain some of these symptoms. Has anybody seen this wonderful Kip quirkyness?
    • 23009
    Re: Kip 7000 "Roll Not Found" messages
    I installed a new IPS today. It took me a little while to figure out that Kip needs to regenerate the key codes. Almost everything is back, except roll3 and roll4, which are now completely gone, not just "load paper". I'm assuming that the extra rolls are an option that must be enabled. Yes?
    • kingarthur
      • 1369
      Have you got any of the previous back ups..."KBK", it's my understanding that when these are restored, all the & network settings and other settings are restored, possibly the keycodes too, but only if it's done correctly, I did a KIP course 2 years ago...and the instructor couldn't understand why the network settings weren't reloaded, it was only when I saw their software tech do it a different way,i realised that the instructor was doing it wrong.......
        • 23009
        Thanks for your response.
        I do not have any backups, nor would I trust a backup if I had one. This IPS has been acting strangely since August. =^..^=
        • jdzr
          • 125
          Try going to keepitprinting.com. This a KIP info website. One of their guys should be able to give you positive info.
