Cheaters
  • subaro
    • Oct 2010
    • 1274
    Cheaters
    What device do you use to cheat interlock switch, door switch and others. Many would not stay put would not fit properly and sometime would even damage the switches if not used correctly. want to hear what you guys use. If you have pics that would be better.
  • theengel
    • Nov 2011
    • 1784
    Re: Cheaters
    A piece of folded paper.
    • harleyrider
      • Oct 2011
      • 348
      Re: Cheaters
      a short length of hose like the old savin tanks had in them. works great last long time.
      • CraigW
        • Dec 2010
        • 417
        Re: Cheaters
        Short lengths of vinyl tubing.
        Grip well, and stay put.
        • subaro
          • Oct 2010
          • 1274
          Re: Cheaters
          Thank you all for the reply. The vinyl tubing works excellent, but must be at least half inch in width. i tried a smaller size but it twist easily and falls out. paper works , but tend not to stay and you have to cut the paper in the correct size ect.
          My trick is to take a tie wrap and bend it in half in a bow pattern with the grip side facing outwards and wrap a piece of electrical wire on the ends. This works very good.
          I use these everday and hates when they slip or keep slowly sliding out and not stay in place. the tie wrap can be thin and will fit in any hole and most likely you would have in your bag if you need a cheater quickly. i should post a pic. this tool, and yes it is an essential tool, saves a lot of time wasting.
          Others may have their own design, please share if you have something ingenious
          • CraigW
            • Dec 2010
            • 417
            Re: Cheaters
            I have a folded zip tie as well, folded the same way (no tape though)
            The softish tubing seems to hold in place best.
            • ZOOTECH
              Senior member of CRS
              • 3375
              Re: Cheaters
              It wedges in pretty well.
                • 23009
                Re: Cheaters
                For years I used 3/8" (10mm) ID vinyl tubing. Bit by bit is been trimmed and used for other things (from 6" down to nothing), until it is completely gone. Recently I dug through my tubing box, and found a very nice 4" length of 3/16" (5mm) ID fuel line. It's very soft, and works better than the vinyl. Like subaro suggests, the best OD is about 1/2" (13mm). =^..^=
                • subaro
                  • Oct 2010
                  • 1274
                  Re: Cheaters
                  Here are two of my cheaters i use every day. these do not slip. i can squeeze it to fit any size hole and adjust easily. I tried many things, but so far these work the best.
                  • Iowatech
                    Not a service manager
                    • 3930
                    Re: Cheaters
                    Originally posted by ZOOTECH
                    I use a Sharp corona cleaner from the mid 90's.[ATTACH=CONFIG]31384[/ATTACH]
                    Those do work really well, unfortunately I broke the last one I had a few years ago.
                    (SF7300? The Lanier equivalent was the 6213 series.)
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Re: Cheaters
                      Canon at least used to sell one as as service tool.
                      Its shaped evolved over the years to fit new models.
                      I think it was made of aluminum, but could have been just about any alloy or compound.
                      I must have had at least 10 of them stashed in various places. I managed to lose them all over time.
                      • Iowatech
                        • 3930
                        Re: Cheaters
                        I actually still have one of those, it has a kind of weird "L" shape with some slots cut into it. I don't use it that much anymore, but with a bit of creativity it used to work well for everything.
                        • Hansoon
                          • Sep 2007
                          • 3389
                          Re: Cheaters
                          Reversed fat Tie Wrap. Hans
                          • ZOOTECH
                            • 3375
                            Re: Cheaters
                            I'll post a photo tomorrow of the one I have, but don't use (haven't seen a Canon in ages).
                            • NeoMatrix
                              Senior Tech.
                              • 3513
                              Re: Cheaters
                              I have a door cheat similar 'L' shape design with slots cut here and there for various makes and models.
                              It was original an ooooldddd Toshiba door cheat. I modified it over the years for Canon, Ricoh ,Sharp, and Brother; and just recently Xerox.
                              It's not always a perfect fit for every slot but it does the job.
