Fuser Question
  • adamcopiercali
    • Aug 2012
    • 88
    Fuser Question
    Hi, I was wondering if anyone could answer this for me. If someone was sent a 110v fuser and they installed it on a copier running 220v, would that short out the fuser rendering it non operational?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: Fuser Question
    Most likely. If you put a 220 in a 110 it will just code because f lack of voltage.
      • 23010
      Re: Fuser Question
      Most likely the lamps would blow within seconds. If the thermostats did not blow quick enough it might melt the upper roller to the lower roller. I've seen that a few times. It's not very easy to disassemble with the two rollers welded together. =^..^=
      • copier tech
        • 8195
        Re: Fuser Question
        I'm not sure that they will physically fit into the wrong machine?
        • gkalman2004
          • 157
          Re: Fuser Question
          it is not wrong machine it is wrong country...
          The same machine can be used in china, us, ue etc..
            • 23010
            Re: Fuser Question
            Certain models are keyed. Some have a jumper in the connector identifying the origin. Others do not, and just error out when the warmup time does not match it's expectations. It depends on what manufacturer/model we're talking about. Did I miss that part? =^..^=
            • adamcopiercali
              • Aug 2012
              • 88
              Re: Fuser Question
              It was a Toshiba 2040c series. Not sure if that helps. Thanks for the info!
