C360 adjusting fuser temperature as it relates to wrapping lower fixing roller ?
  • pick
    • Oct 2015
    • 26
    Intermittent wrapping the lower roller on a Konica C360 . Not sure if fuser temperature change will correct or just making a Thick paper change will correct fusing issue ?
    • 37459
    Re: C360 adjusting fuser temperature as it relates to wrapping lower fixing roller ?
    You have posted in the wrong forum. Post your problems in the correct Technical Forum not the System Forums.
      http://www.copytechnet.com/forums/misc.php?do=vsarules
        • 23006
        If it's heavy fill images check that your leading edge void is 4.0 to 5.0mm. If duplexing, also 4.0 to 5.0mm at the trail edge also. =^..^=
