Brother DCP L5652DN out of alignment
  • Carlos oliveira
    • Sep 2019
    • 7
    [Misc] Brother DCP L5652DN out of alignment
    Hello,
    I have a problem with image alignment on the sheet, the toner cartridge, photoconductor unit, and fuser unit have been replaced. Factory settings reset (maintenance 01). Photos of the attached problem, drawer and bypass tests, normal front and back, normal sheet, and thick sheet.
    Grateful for the attention.
    WhatsApp Image 2020-01-08 at 14.52.44.jpgWhatsApp Image 2020-01-09 at 08.39.35.jpg
  • GIUBOSS
    • 1331
    Re: Brother DCP L5652DN out of alignment
    clean the color alignment sensors, and the part relating to image transfer. Consumable counters?
      • 22808
      Originally posted by Carlos oliveira
      Hello,
      [ATTACH=CONFIG]44562[/ATTACH][ATTACH=CONFIG]44563[/ATTACH]
      if you upload in PDF format it gives better image due to position of your camera.
      As Guiboss said clean sensors
      also front to bad prints won't line up like you think they should..depending on BORDER spacing.
      if printing from PC to different trays make sure the guides are set properly
      • Carlos oliveira
        • Sep 2019
        • 7
        Hello, how are you? Problem occurs when printing the report through the equipment and printing from the PC, regardless of normal front or front and back, the first sheet is out of alignment and the second is normal. All paper settings or drawer adjustment are correct. Tests were performed with the parts mentioned above.
          • 22808
          like I said before.. .jpg files are hard to judge size and borders.
          .PDF work a lot better
          • Carlos oliveira
            • Sep 2019
            • 7
            .PDF work a lot better[/QUOTE]
