What chemicals do you use to keep your printer clean?
  • JasonMcDowell
    • Oct 2017
    • 22
    I have read a lot about the chemical synthesis elements and results of their application to the simple ones. Do you know anything for the printers? May be anybody uses?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4722
    Re: What chemicals do you use to keep your printer clean?
    Not sure if you mean to clean the covers but after many years using harsh chemicals I switched to all organic cleaners. Safer for me and the enviroment. Only difference now I have to scrub a lot harder with the brillo pad!
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      I use degreaser /auto mechanic grade/ to scrub the smog grime off the plastic covers (the spots that won't go with regular soap formula). Results are excellent.
      My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        • 23009
        I carry 1 oz bottles:
        Isopropyl Alcohol 71%
        Contractors De-Solv-It (orange oil based solvent, undiluted)
        Glass Cleaner (formula: -20F 2Gal windshield washer solvent, 2Qts Vinegar Windex, 1Pt Cleaning Vinegar)
        Triflow Oil
        Marvel Mystery Oil
        Straight 30W Motor Oil (scanner rail oil)
        Canon EU-1 (plotter carriage rail oil)
        HP500 high temp grease
        Mobilgrease28
        Paraffin Lamp Oil (or Dispersant if you can still get it)
        Zep Fast505
        Honestly I haven't used the Marvel in a long time. Originally it was for Sharp plastic spring feed clutches, but is good for lubricating the tap when making threads.
        The manufacturers must have refined the scanner construction. I haven't had to lubricate a scanner rail in ages.
        • rapidocument
          Multibrands Tech
          • Jul 2012
          • 381
          A long time ago I saw a xerox tech using gun oil for rail scanners, (birchwood casey's).
          • NeoMatrix
            Senior Tech.
            • 3513
            ( random snip)
            Thanks BC...
            You just triggered a light bulb moment for me.
            My water taps are always cutting the rubber tap washer, which reduces their life. I believe I will try an place silicone grease inside the tap/plunger to allow the tap to twist while the rubber ring stays fixed to the watertight seat; at least for the first quarter turn. I feel the rubber washer tears its gripped by the rusty water tap and the watertight copper seat....
            I will let you know if I get any extra life out of my tap washers....
            apology for topic tangent...
            • JasonMcDowell
              • Oct 2017
              • 22
              custom synthesis with Custom Synthesis | Ereztech
              I meant anything useful and reliable. To keep it clean as the screens of the different laptops etc. May be it is chemical one or not. Anyway, I want to have a good result and more leisure time.
              • Blizzoo
                • Aug 2013
                • 608
                Ambersil Amberclens Anti-static Foaming Cleaner 400ml for cleaning the dirty covers.
                • tsbservice
                  Field tech
                  • 8020
                  Quote Originally Posted by JasonMcDowell View Post
                  Another RC for posting repeatedly this bolded underlined shit.
                    • 37532
                    For cleaning screens you cannot beat Windex.
                      • 37532
                      There is no one cleaner does it all. Everything techs here have mentioned is useful and reliable.
                        • 23009
                        Thanks BC...
                        Look for something called Dow Corning 111 (or something similar).
                        Dow Corning 111 O-Ring Silicone Lubricant (5.3 oz Tube) | Serv-A-Pure
                        It's a food grade plumbers grease. The 150g tube should last me several lifetimes. About 4 years ago I did some research and discovered that petroleum based lubricants attack the rubber seal, shortening it's life (like Vaseline).
                        Around that same time I was changing the O-ring seals on the fuel injectors of the wife's Cadillac. They needed some sort of grease to get everything to slide together. I reached for the Dow Corning ... then got to thinking: "hmmm ... fuel lines and fuel seals MUST be resistant to petroleum products, so THIS is the place to use the Vaseline."
                        • JasonMcDowell
                          • Oct 2017
                          • 22
                          Thanks for the offer. Why not do it here! It'll be great, I think!
