image issues
  • Brandon
    • Jun 2019
    • 72
    image issues
    Good morning
    I have an Olivetti d-Copia 5200MF that is smudging / smearing the text/image in certain places , i have tried another drum unit and developer unit but has made no difference see attached sample
  • GIUBOSS
    • 1436
    Re: image issues
    check how many pages have the drum, blade, in case replace. Clean the surface of the magnetic roller with a dry cloth.
    • Brandon
      • Jun 2019
      • 72
      Re: image issues
      I have swopped drum and developer units with another machine to check and the fault doesn't move over with the drum and developer unit to the other machine is stays on the machine even with a different drum unit and developer unit
        • 23009
        Re: image issues
        Have you determined yet whether this is an ADF issue or a printer issue?
        Common on Toshiba document feeders: You can get a blur line ~50mm from the trailing edge of the original. Very difficult to resolve with mechanical adjustments. =^..^=
        • Brandon
          • Jun 2019
          • 72
          Re: image issues
          Hi All
          thank you for all the input received , i have sorted the issue out
          the problem was on the transfer roller , the holder and spring was broken and missing on the one side replace the holders and springs and issue sorted
            • 23009
            Re: image issues
            Congratulations on your success. =^..^=
