HP M608 will not fuse toner
  • emujo2
    • Mar 2017
    • 1579
    [Misc] HP M608 will not fuse toner
    I have a M608 that was calling for a fuser maint kit. We received one that would not heat up, so ordered a replacement. This one will heat up, but will not fuse toner to paper. Image looks pristine, but toner rubs off with finger. We are all KM techs thrown into HP repairs with limited access to manuals and TS guides..Our printer support group has no clue and says get dc power supple and main board.."that might work"..any ideas from actual HP folks? TIA, E
  • GIUBOSS
    • 1436
    Re: HP M608 will not fuse toner
    OEM kit or refurbished? you took a look at the paper settings. Firmware update?
      • 23009
      Is pressure being applied to the fuser rollers? Any special media? What media settings are you currently using? =^..^=
      • DRichard
        • May 2008
        • 482
        From the manual...
        1. Reprint the document.
        2. Check the paper type in the paper
        tray and adjust the printer settings to
        match. If necessary, select a heavier
        paper type.
        3. Enterprise models only: From the
        printer control panel, go to the Edgeto-
        Edge menu and then select
        Normal. Reprint the document.
        4. Enterprise models only: From the
        printer control panel, select Auto
        Include Margins and then reprint the
        document.
        5. If the problem persists, go to
        support.hp.com.
        "Enjoy every sandwich."
        -- Warren Zevon
