OKI C833 Error code 310 "Close top cover/ Front Cover"
  • Jinn
    • May 2023
    • 114
    Hi,
    Oki c833 is giving error 310 to close top, exit / front cover. While the top and the front covers are already closed. I have checked the open close switches they are working fine (CONTINUITY) I do not know what happened. It started showing this error all of the sudden.
    Can anyone shed some lights here? Please
    • 22997
    Check to see that the 24vdc is present at the door switches. If no, it's pointing towards a fuse on the power supply, or more likely, the whole power supply.
    • Jinn
      • May 2023
      • 114
      Thank you so much for guiding.
      After checking volts at the switch it is found zero. As you said check fuse in the power supply. The fuse is working. Now have to cross check power supply. Can you tell me which component goes dead when the supply does not work?
