applying grease to a printer
  • aviso66
    • Dec 2012
    • 202
    [Misc] applying grease to a printer
    hi guys, I am just wondering or any one has a layout of a map that gives a marking on a copy machine tat say the parts needs or can apply grease to it?
    • 22999
    Re: applying grease to a printer
    Most service manuals have such information. Did you have a specific machine in mind? =^..^=
    • aviso66
      • Dec 2012
      • 202
      erm lets say ricoh copier.
        • 22999
        You'll need to get that from one of the Ricoh guys ... it would probably be helpful to know what model you had in mind. You'll probably find that specific manufacturers have very different answers to that same question.
        Here are some general rules that I follow on most machines (with some specific exceptions):
        MobilGrease28 (clay based thick grease, aircraft specification)
        Spring Clutches (you don't see too many of those any more)
        Spring Torque Limiters
        Plastic-on-plastic or plastic-on-metal friction/squeaks
        TriFlow
        (light oil)
        Oil impregnated bronze bushings
        Bearings
        Metal Shafts (not near developer or toner)
        Torringtons (one-way bearings)
        SW30 Motor Oil
        Scanner Rails (use minimum)
        Conductive Grease
        High Voltage Contacts
        Drum Shafts
        Bias Contacts
        High Temperature Grease (HP500)
        Heat & Pressure Roller bearing/bushing surfaces
        Fuser drive gear (bores only, no need on the teeth)
        Silicon Oil (Fuser Oil is very model specific, so use manufacturers recommendations whenever possible)
        Things that NEVER get lubricated under any circumstances:
        Leather torque limiters
        Magnetic torque limiters
        Electromagnetic Clutches
        Photointerrupters (?!?!?)
        Those are my general rules. I'm sure there will be many more opinions! =^..^=
        • dalewb74
          • Feb 2018
          • 1135
          just as blackcat said. you need to know a specific brand and model. even same brand different models is gonna require lubrication in different areas. its not a generic all for one.
