Olivetti 3023/3024
  • brantekcc
    • Jan 2022
    • 45
    Olivetti 3023/3024
    Good day
    I have 3x Olivetti 3023/3024 machine all making a noise relating to the transfer belt , i have taken one of the belts and cleaned out the cleaning section and also vaccuumed out the shoots that feed the toner into the dev tanks , it works for about 5-8 pages and the nosie returns
    has any one had this issue before and how was it reolved please
  • techsxge
    • Jan 2022
    • 660
    Re: Olivetti 3023/3024
    Originally posted by brantekcc
    Good day
    What does the Noise sound like? Could be the transfer belt toner hopper that is clocked up bc the waste toner box hopper is not opening properly
      • 23002
      That looks like a Kyocera ECOSYS M6535 ... maybe something in the same family?
      If the waste toner system is backing up, it will back up through those ports in the transfer belt, back to the transfer belt & drums. Often the auger shaft breaks, so there is no mechanical noise to give away the location of the damage.
      It is a major operation to remove the waste toner auger system from the right frame of the machine. I would not attempt it in a customers office.
      I had the pleasure of re-assembling a machine that someone else had disassembled over a period of days. =^..^=
