C3851fs copy only blue or red fine lines
  • stevewm1121
    • Apr 2023
    • 1
    This should be easy for someone!
    Closest I've seen on here are the "lines of shame" but those solutions didn't work
    (see attached) this is a scan of the results from copying
  • Synthohol
    Certified Konica Expert
    • 5815
    Re: C3851fs copy only blue or red fine lines
    those indeed appear to be lines of shame.
    was the initial setup followed exactly in order with no steps skipped?
    is time and date correct?
      • 37449
      If it only happens when copying, it most likely has something to do with the scanner. You may need to replace the lens/CCD
      • Woxner
        • Jul 2011
        • 845
        those are line of shame indeed. something got reset to factory and not set up properly.
