Using Toshiba toner in Oki MPS3537mc & MPS4242mc
  • Samanator
    • Sep 2017
    • 575
    My boss is having a hard time finding toner for the Okidata MPS3537mc & MPS4242mc. He has found the equivalent toner for the Toshiba 347cls and 407cls. But for some reason I cant seem to make them work. I have moved around the black tabs on the side of the Toshiba toner to match the way they look on the Okidata toner but is still doesn't seem to work.
    What am I missing?
    Thanks in advance for any help.
    • 22999
    Re: Using Toshiba toner in Oki MPS3537mc & MPS4242mc
    Is there a chip? If the old cartridges haven't reached end of life, maybe you can recover the toner only, and re-fill?
    Messy, I know, but you're running out of options. =^..^=
      • 8146
      ... this copier (discontinued) was a nightmare for toner cartirdges. Trying to find the Okidata OEM original toner is a very long shot considering that Okidata abandoned the North American print market in 2022.
      The toner is definitely " chipped" unigue to the OEM.
      Do yourself a big favor and upgrade your copier to a new Toshiba e330AC.
      • Samanator
        • Sep 2017
        • 575
        I have to ask, where is the chip located?
        Is it easy to remove?
        • Samanator
          • Sep 2017
          • 575
          Found the chip.
          Still no joy.
          • austonrush
            Sharp & HP Tech
            • 234
            Iteminc.com is the only North American distributor for Oki now. Did you check with them?
