i was told this error is indicating that the polygon motor is bad...if this is true do you know the part number?
Imagistics IM 3511 L6-10 error
It is true-LSU. But I have only Sharp part numbers.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
patrickj420
Which Sharp? AR-M280N, AR-M350N, AR-M450N? Each laser unit is different.If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
patrickj420
