Imagistics IM 3511 L6-10 error
  • patrickj420
    i was told this error is indicating that the polygon motor is bad...if this is true do you know the part number?
    • 23010
    It is true-LSU. But I have only Sharp part numbers.
    • patrickj420
      Interchangable??
      Do you know if the parts cross from IM to sharp? They are the same box I think.
        • 23010
        Which Sharp? AR-M280N, AR-M350N, AR-M450N? Each laser unit is different.
        • mansart
          • 855
          IM3511 is a reboxed Sharp ARM355n
          Sharp number for LSU is DUNT-7093DS17
          • patrickj420
            Thanks!!
