hp 5000n
  • paul printer
    • Aug 2025
    hp 5000n
    i am an offset printer, i use a hp 5000n printer to make plastic offset plates, they will only work with genuine hp cartridges, in between making offset plates, i print ordinary pages, is it alright to keep changing from generic cartridges to genuine ones frequently.
    thank you, paul printer
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    There should be no problem with that outside of the usual issues that crop up from non-OEM cartridges. You will probably see a little toner scattering and the copy quality can sometimes be less than the HP cartridges, but you won't hurt anything by swapping them out.
    • lonesome
      Nothing special really. If you are aware of the dangers of substandard cartridges and non-oem... then you're good.
