How to implement key counter interface to copy terminal?
  • syazelle
    • Jul 2025
    Hi,
    I'm a electronic student and right now I'm developing a copy terminal (user can release print job via the terminal etc). After a while, I realized that certain copier has a function called Key Counter Interface that can lock/unlock the copier via the terminal.
    After some research, I still do not fully understand how it works and how to implement this function to my electronic board. If someone has a example implementation or explication, I'll be very grateful.
    Thanks for your time.
    Regards,
    Maryam
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    All manufactures probably don't do it the same. Most are pretty simple, in my experience. I believe the Ricoh units use a four wire system. In generic form you only need a signal to activate/defeat the key counter message, output line/s to run the counter on the external counter (depends on your setup) and possibly an activation signal from the key counter unit to the copier.
