oki c9600 says wait adj temp
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Customer complaining of files taking a long time to print. When you turn on the printer...the first job you send to it prints quickly. Then later other jobs you send to the printer do print but the unit takes a long time before printing them. Display says wait for a while then adjusting temp then prints job. Fuser has been replaced by a brand new oem fuser. Problem continues....Any ideas?
  • Holesaletech27
    • Jul 2009
    • 101
    I've had an issue with the transparency detect sensor with other oki models causeing delay in print jobs(showing adjusting fuser temp). I'm unsure if this model has one, but it might be worth a go.
    • Eric1968
      • 2458
      Try setting the paper weight to a fixed value. Sometimes the thickness sensor can not detect the weight properly. This results in warming up and then cooling down. Setting the weight to a fixed value resolves this problem.
        • 22997
        If the customer is printing thick paper, there is an additional warmup time to reach the higher fusing temp. If they're using the thick paper, it's required for proper fusing. =^..^=
        • tcs04
          FORMER Techie
          • 1183
          WHOA!!! I just logged on to this post to suggest EXACTLY the same thing!! had this 1 month ago (BA^%**!D fault!!)
          Can apparently be turned off to confirm the fault (not sure how but can find out if required)
          Also will cause the machine to run slow!!
