samsun ml2855nd makes loud noise when printing
  • mikeleitold
    • Aug 2025
    any info on why this model printer would start to make loud noise while printing. I am going to see it tomorow but any heads-up would be nice. mike
  • tstahlfsu
    • Jan 2011
    • 21
    If its a loud grinding noise, may be the fuser is not fully seated.. Other that that, normal diags apply
      • 23010
      Watch out for compatible cartridges. They can become too difficult to turn, and stall the main motor. =^..^=
      • mikeleitold
        thanks for the reply's...client was using re-man cartridge, she will change cartridge and call back if it still makes noise. I herd it over the phone and it sounds like the main motor is forcing to turn over the cartridge. mike
          • 23010
          Don't assume that a second compatible cartridge will be any better than the first. I had a customer walk in with 4 cartridges that would not turn. OEMs worked fine. =^..^=
