sc 672
  • Muzammil
    • Jun 2025
    [Error Code] sc 672
    i am facing sc 672 in gestetner highspeed machine model MP1350 and i want to know how this code will remove.
  • jonhiker
    • 661
    SC672 Controller startup error
    After power on, the line between the
    controller and the operation panel did
    not open for normal operation.
    After normal startup, communication
    with the controller stopped.
    Controller stalled
    Controller installed incorrectly
    Controller board defective
    Operation panel harness
    disconnected or defective
    Try powering the machine off all of the way, that should reset it it. Other wise check all of the connections on the controller board and op panel. You may need a new controller board.
    • pLatik
      • 169
      i have this issue recently, and i have to replace the controller board.
