Tech mode for clx-3175 ?
  • KHAN
    • Aug 2006
    • 261
    [Error Code] Tech mode for clx-3175 ?
    Hello, Please how to Enter the TECH MODE of Samsung CLX-3175, there no key pad in my printer just menu and left/rigt arrows and stop , start buttons,
    Please also tell me which is the best ckt and program to read/write the EEProm of this printer or how to Reset the toner CHIP ?
    THANKS.
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
      • 23010
      Press: Menu, #1934, Menu, "Tech Mode <Tech Mode>" OK. =^..^=
      • KHAN
        • Aug 2006
        • 261
        Thanks for your help, as i told in my POST there is no numeric keys in my printer,just the big menu key with left/right arrow and two start one for color and the other is for black copy.please need help for how to reset the Toner chip also.
        THANKS
          • 23010
          Then it's not a CLX-3175. Could it be the printer engine CLP-315?
          • KHAN
            • Aug 2006
            • 261
            My friend it is CLX-3175 simple with out fax and networking, I download CLX-3175 driver and Smart panel from SAMSUNG site and it works fine, if it is other model then how can it works with CLX-3175 driver ?
              • 23010
              This is a CLX-3175. You must have something else.
              Sometimes if you use the wrong print driver it can work. Not consistently, but its possible.
              I think I'm done with this conversation.
              • KHAN
                • Aug 2006
                • 261
                Thanks blackcat for your kind help, It is not a MFP it is in Black color and simple CLX 3175, I you search samsung web you will find CLX 3175 in black color and the Panel is with out numeric keys,
                THANKS A LOT FOR YOUR PRECIOUS TIME, GOOD BLESS YOU.
                • ic3cold
                  Re: Tech mode for clx-3175 ?
                  Hello, I also have a Samsung CLX-3175, and it's without a keypad, but you can enter Tech mode by clicking certain keys in sequence, I finally get into tech mode, although what I wanted to do was to reset the page counter to STOP the 'Empty Toner' error, I cleared page CNT, but to no effect so if anyone here experienced with tech mode, can please tell me what to do from there I will appreciate it!
                  In fact It's possible to enter the password once you get thereby clicking LEFT and RIGHT, right moves up the count and Left moves down, so Right, goes 1, 2, 3 ... so one, and left goes 0, 9 ... 1, after you enter 1934, you have to click OK each time you enter a number.
                  • autopilot
                    • May 2011
                    • 68
                    Random I've had this before and had to work it out, literally just went to one again expecting there to be a number pad and have fallen into the same trap.
                    ic3cold
                    How do you get into tech mode its Menu ID copy something or other isn't it?
                    Sidenote: Is this a UK thing or what? Even the service manual I have just says to type the numbrs in.
                    • autopilot
                      • May 2011
                      • 68
                      To enter Tech Mode on a Samsung CLX 3175 (the black machine without numeric keys)
                      With the machine at ready to copy....
                      Press Menu, Copy ID, Left, Right, Menu, Back
                      The next time you press the menu key you can navigate the tech menu, if you try to do anything of significance in there it will ask for a password which is the usual 1934, use the arrow keys to change the number and press OK to move on to the next one and Ok again when finished.
                      Any error lights or maintenance messages you expect to clear will remain until you exit tech mode which im sure there's a way to do but turning the machine off and on seems to do the trick
                      • Toonforce
                        Thanks, that works for me. But do you also know how to enter the EDC-Mode? I want to check some sensors by hand.
                        • autopilot
                          • May 2011
                          • 68
                          Software apparantly...
                          Theres more info here than I'd be able to give you
                          http://www.copytechnet.com/forums/ot...lx-3175fn.html
